Randy G. wrote:Sour shots are usually due to low brew temperature.
Our machine only offers 3 configuration settings: hot, hotter, hottest. We are currently using the hottest setting. Maybe this is an indicator that our heating element is failing?
Randy G. wrote:As far a quality grinder + super auto improvement, it depends on the condition of the Jura as to whether this will address any problems there.
I guess I'll wait to hear back from the service center.
Randy G. wrote:You could get the grinder and another brewing device (I love the Espro Press) so a grinder can be more than just for espresso.
We do have a french press and it never gets touched. How does the Espro Press compare with a mokapot?
Randy G. wrote:I think that if the machine is used primarily by your wife, she is the one who needs to make the decision.
Probably true, but she tends to defer gadget purchasing decisions to me since I am more obsessive about reading up on whatever it is we might be getting.
Randy G. wrote:There are more steps involved in using a machine+grinder, and these have to be done with some level of precision to produce good results. Only she can decide is that is something she wants to do (or you, if that is the case). I also think a dual boiler will be less fussy, and coming from a super-auto that is a factor to consider.
We are both engineers so being precise shouldn't be an issue for us. I've mostly ruled out HX machines because the idea of listening to the sounds a boiler makes while heating up to find an optimal time to pull a shot would probably overwhelm her.
Randy G. wrote:The truth about needing a quality grinder is less a truth and more from the mouth of G--. It's a waste of money buying a good espresso machine otherwise. It's even a waste of money buying a bad espresso machine if you don't have a quality espresso grinder.
So what is the rule of thumb for pairing a grinder with an espresso machine -- match dollar for dollar? I have a short list of community favorites ranging from $450 to $2k and don't really understand what the higher price points are buying me.[/quote]
Intrepid510 wrote:It sounds like something along the lines of a double boiler would be good since it has that walk up and make a shot approach. I know my wife won't even touch my little Gaggia Classic because she doesnt seem to want to deal with it at all. Have you thought of something along the line of a Quickmill Silvano?
sweaner wrote:If I were making a similar choice now I would think about the Quickmill Silvano, Crossland CC1, or Breville Dual Boiler. I would pair these with a Baratza Vario.
Is there anything specific that you guys like on the Quickmill Silvano? I noted while looking over the specs that it doesn't allow for a direct water line (and drip line), which is a convenience that I am willing to pay extra for.
