by boar_d_laze on Sun Jul 31, 2011 1:38 am
PID compared to what? A DB PID compared to an HX? Or a PID compared to a pstat?
A good DB PID doesn't allow that much more control compared to a very good HX, but is somewhat thriftier in terms of water use, and hence more convenient if you're not plumbed in. In your price range, the pour-over DBs usually have better steam capabilities than pour-over HXs.
It's just not that hard to control a good HX's brew temps. Especially not after you've been using the same machine for a few weeks. And please remember that "the morning after score" is something you'll have forgotten very early in the machine's life cycle.
The $2500 and under price point seems to have an embarassment of high quality DB PIDs including the Izzo, Brewtus, La Spaz, VBM DD, etc. They're all very good, and if used in such a way as to optimize their capabilities will each brew exceptional coffee.
Choose something you can get serviced, which has all the conveniences you want (such as a big drip tray, plumb-in capabilities if that becomes possible for you, a reservoir which can be filled without removing the cup tray, etc.), and perhaps an E-61 group if you believe they have some special juju. Buy something you find attractive and which you enjoy touching (and wiping down). If you don't want a big, square, shiny box with an e-61 hanging off the front you don't have to have one. If that's what you want, you've got a few possibilities.
If you're getting a rotary pump, you probably want some degree of pre-infusion. You probably already know that the principle advantages of a rotary are how they handle plumbing in and lower noise. Their disadvantage is their very fast pressure ramp up. Hence, the need for pre-infusion, or something like it. The alternative is serious barista skills and an always-attentive barista. The first isn't impossible, the second is tough to find in the morning.
Good luck,
BDL
